Hi there
I suddenly have a red box/frame/line around emoticons. Where did they come from and how do I get rid of them?
I'm running Confluence 3.4.9
Rune
Can you utilize a developer tool (firebug) to inspect the element and see if there is css applied to the image as a border?
Chrome has this built in natively, firefox you'll need to install the dev tool firebug.
Hi Rune,
Are you talking about the error box macro? https://confluence.atlassian.com/display/DOC/Error+Box+Macro+-+Example+of+a+User+Macro
If this is the case, you can simply delete the macro and the box will disappear.
I hope this helps. :)
Rodrigo
Hi Rodrigo
No its not. I have tried to upload an image of the issue:
