Redo/do-again action shortcut (NOT after undo)
Ori_Bandel
November 6, 2019
Hola!
I'm wondering if there is a Re-do or Do-again shortcut/button in Confluence?
Something like F4 in Word, which does-again the last typing been made (kind of duplicates the last typing).
I'm NOT referring to re-do (⌘ + Shift + Z) after an un-do (⌘ + Z) shortcut.
Your assistant is vital and precise!
Ori
Manisha Kharga {Appfire}
November 6, 2019
@Ori_Bandel ,
If you are using Mac then you can use the command+Z option to undo the content in Confluence cloud.
There is also the Atlassian ticket raised for this feature.
https://jira.atlassian.com/browse/CONFCLOUD-58034?_ga=2.201603090.2097421106.1572845582-246696911.1568007834
Manisha
Ori_Bandel
November 6, 2019
@Manisha Kharga {Appfire}
Thanks for your answer!
Unfortunately, my intent is NOT to the simple undo (command+Z) and/or the redo(command+shift+Z) but to do-again function that exists in Microsoft Word (and which is extremely useful).
Thanks you!
