Reference a form within same page in a template
Markisio
Hi There
Here is what I have
Form1: has product list
Form2: Smart dropdown of products from form1
both forms on the same page, however I want to create the page as a template and/or global template but I can't reference @self in Page where the ConfiForms Form is defined, is there away to reference itself within a template?
so if the user create a page from template they don't have to worry to edit the page
thanks
Alex Medved _ConfiForms_
Hi @Markisio
You will need to use Confluence storage editor and set the smart field reference to [entry._page] instead of an actual page ID (for smart field configuration)
Alex
Markisio
THanks @Alex Medved _ConfiForms_ do you know the steps to get to confluence storage editor please?
