i added the following confliguration in my setenv.sh =>
-Xdebug -agentlib:jdwp=transport=dt_socket,address=1043,server=y,suspend=n
i see in my logs the following line =>
Listening for transport dt_socket at address: 1043
So I suppose that I normally can connect on the port 1043 with my eclipse, but i doesnt work...
I have no probleme to remote debug on a windows server, but hier it's a linux and it fail...
What's the difference? and what I'm missing?
Thanks.
François
François, have a try in it!
Step 1 - Edit catalina.bat:
Go to your atlassian-jira-x.x.x-standalone/bin and open catalina.bat in an editor.
Find the following chunk of code:
1 2 3 4 5 6 | rem set _EXECJAVA=%_RUNJAVA% rem set MAINCLASS=org.apache.catalina.startup.Bootstrap rem set ACTION=start rem set SECURITY_POLICY_FILE= rem set DEBUG_OPTS= rem set JPDA= |
and replace it with:
1 2 3 4 5 6 | set _EXECJAVA=%_RUNJAVA% set MAINCLASS=org.apache.catalina.startup.Bootstrap set ACTION=start set SECURITY_POLICY_FILE= set DEBUG_OPTS=-Xdebug -Xrunjdwp:transport=dt_socket,address=7456,server=y,suspend=n set JPDA= |
Notice that address=7456 means that this port will be available for debugging. You can use any other port you want.
Step 2 - Add external run configuration in Eclipse
Now you have your debugging mechanism all set up. After you start jira, just run this debugging configuration (Debug As -> Debug Configurations -> Your configuration) and place your breakpoints wherever you need them.
Cheers
