Replace and Render not working properly in Confluence 4
Michael Roff
September 9, 2012
I am using a replace and render to determine the correct page to create a child page under based on the current year. This works in C3.5.16.
The code I am using is wrapped in a wiki-markup wrapper.
<code>
{replace-and-render}
{replace-body}
{note}
{center}
{create-page:template=CoC|title=%title%|parent=%parent%|mode=edit}Click to submit your confirmation.{create-page}
{center}
{note}
{replace-body}
{replace-item:%title%}{report-info:variable:Year|format=#} Coc Confirmation - {report-info:global:current user > user:full name}{replace-item}
{replace-item:%parent%}{report-info:variable:Year|format=#} Coc Confirmations{replace-item}
<code>
This produces the following error:
Has anyone encountered similar problems or know how to get around this?
Cheers, Mick
Michael Roff
October 7, 2012
I have an update on this.
I have found that it is not necessarily the replace-and-render that isn't working properly, I think it is the wikimarkup plugin that is having problems.
It seems that the wikimarkup plugin is not accessing the variable Year correctly through the report: {report-info:variable:Year}
As this is sufficiently different from the topic of the thread, I have created a new thread for this particular issue.
The thread is here: https://answers.atlassian.com/questions/93648/wiki-macro-not-accessing-variable-value
