Required Security Token was not present in request.
Alex Davidson
My users are seeing this error when saving freshy edited pages in Confluence 5.4.4. We've been using 5.4.4 for sometime without problems. Any pointers?
William Zanchet [Atlassian]
June 13, 2014
Hey Alex,
May I ask you if you have Confluence and JIRA running under the same ip address and the only difference is the port? If yes, that is caused by the cookies that are shared by the two applications, so in order to fix it we need to apply a context path to it.
WZ
Bruna Griebeler
June 9, 2014
Hi Alex,
Do you have SSO enabled? Are these users using another Atlassian product as well? If your SSO is not working properly, when te user logs in in another application (on the same domain), the session times out.
Jobin Kuruvilla [Adaptavist]
June 9, 2014
Usually happens when the session times out. Is that the case here?
See inside
