Hello there,
i want to set restrictions on a confluence template, so that only certain groups can create pages via this confluence template. How can i do this?
Or can I configure a confluence template, via comala workflows, so that it always started with the same workflow? For the most pages I use another workflow. I have then two concurrent workflows on a space. Is this possible? The first workflow I want to use to creat parental level. The second vor normal pages.
Regards
Daniel
Basically from what I see it is related to Comala workflows.. When you want to restrict specific workflow to a page I think labels can be used.
More information can be found here in a similar topic
For restrictions there is a documentation
https://wiki.comalatech.com/display/CWL/Add%2C+remove+and+set+page+restrictions
