Check out this screen shot. Notice how the editor looks one way but after I save it I get completely different results. Note the location of the bars, the Today line, the start of the timeline, etc. Any ideas? I could not find this as a known defect.
Hi John,
I think it's possible you are running into this bug:
Can you confirm? It's currently being fixed and so you can expect a fix shortly if you are on Confluence Cloud.
Shannon
Yes! I believe CONFCLOUD-57752 is the main issue I am experiencing. Everything comes out wrong...the week setting at the top, the today bar, the placement of the project bars, this is a really serious issue. We switched to Giffy which kinda works... :( Thanks. I started watching that one as well.
