I currently have Confluence, Mysql, and nginx runnig in their own docker. I created a container for synchrony but can't get collaborative editing to work. I'm wondering if anyone has figured it out.
Hi @Luke Bay,
Can you tell us what specifically you aren't able to get working?
Have you used the steps in this article to create the node and run Synchrony as a service?:
If not, I would start there. If you have done that, is the issue that you can't get collab editing to work at all with Synchrony running, or is the issue only occurring once you turn the Synchrony node into a docker container?
Justin
