HI All,
Follow this https://confluence.atlassian.com/display/DOC/Running+Confluence+Over+SSL+or+HTTPS
now i cannot restart the services?
Any idea?
AS
Running confluence over ssl or https .http://youtube.com/watch?v=1FJjdaeh-eY
Hey Asela,
We could see that the last comment from Atlassian was related to pointing to an expert in order to configure the TMG 2010, right? Given that, can you share which solution have you searched, so if other users face the same behaviour, we can take a look at this answers post for reference? :)
Giu
How did you fix?
Hi All,
Now i have manged to start the service with https://localhost:8090but cannot access https://localhost:8443/
Yes. redirect port: 8443
<Connector port="8443" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" maxSpareThreads="75" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" SSLEnabled="true" URIEncoding="UTF-8" keystorePass="changeit"/> keystoreFile="C:\Program Files\Atlassian\Confluence\jre\lib\security/cacerts"
This keystorefile location is correct?
So we we cannot redirect to https? Any steps to troubleshoot?
As
What does the tomcat logs says when you start up the application? Are you getting any binding exception on port 8443?
HI, Create the support Request Reference: CSP-127923 but still couldn't find the solutions?
two days sending emails...
As
HI
Very new to Conflunce and now i can start the service after i copy back from the backup.
so port 443 is not the issue. but when i go to the https://conflunce.mydomain.comnothing works.
also my ssl certificate is wildcard certificate *.externaldomain.com .
which log file should i looked or post?
As
What do you mean by "port 443 is not the issue" - have you tried to start your service with the SSL Connector using 8443 (you have to reconfigure the HTTP Connector redirectPort too). Is this working or not?
What do you mean be "nothing works" - what is the browser telling, can you get your certificate?
@Logs: confluence\data\logs\atlassian-confluence.log --> Might be a huge file, so log if there are any exceptions or errors
HTH, Sabine
HI,
<Server port="8000" shutdown="SHUTDOWN" debug="0"> <Service name="Tomcat-Standalone"> <Connector className="org.apache.coyote.tomcat4.CoyoteConnector" port="8090" minProcessors="5" maxProcessors="75" enableLookups="false" redirectPort="443" acceptCount="10" debug="0" connectionTimeout="20000" useURIValidationHack="false" URIEncoding="UTF-8" keystorePass="changeit" <Engine name="Standalone" defaultHost="localhost" debug="0"> <Host name="localhost" debug="0" appBase="webapps" unpackWARs="true" autoDeploy="false"> <Context path="" docBase="../confluence" debug="0" reloadable="false" useHttpOnly="true"> <!-- Logger is deprecated in Tomcat 5.5. Logging configuration for Confluence is specified in confluence/WEB-INF/classes/log4j.properties --> <Manager pathname="" /> </Context> </Host> </Engine> <!-- To run Confluence via HTTPS: * Uncomment the Connector below * Execute: %JAVA_HOME%\bin\keytool -genkey -alias tomcat -keyalg RSA (Windows) $JAVA_HOME/bin/keytool -genkey -alias tomcat -keyalg RSA (Unix) with a password value of "changeit" for both the certificate and the keystore itself. * Restart and visit https://localhost:8443/ For more info, see http://confluence.atlassian.com/display/DOC/Adding+SSL+for+Secure+Logins+and+Page+Security --> <Connector port="443" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" maxSpareThreads="75" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" SSLEnabled="true" URIEncoding="UTF-8" keystorePass="changeit"/> keystoreFile="C:\Program Files\Atlassian\Confluence\jre\lib\security/cacerts"/> </Service> </Server>
ok, you are using the standard SSL port 443. Is this port free (no Apache or other process using this port). Can you start the server if you try to use 8443? Just to check if it is an port issue.
HTH, Sabine
According to issues triggered by the certificate please check if you have one of the following exceptions in your Confluence/Tomcat Log:
http://tomcat.apache.org/tomcat-7.0-doc/ssl-howto.html#Troubleshooting
HTH, Sabine
can you provide more details to the changes you made? Version you are using? server.xml etc. Any log file available. For example - the connector might not start because of port already in use by another process.
Thx, Sabine
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!Online forums and learning are now in one easy-to-use experience.
