Running Confluence on Port 80
Luis Mayora
September 18, 2012
Does anyone know the steps to run confluence on port 80 using Linux. Already follow the instructions for the server.xml but it is not working.
Luis Mayora
October 9, 2012
I did use a tcp redirect to port 8090 since this is a linux kernel security feature. I wasn't thinking on installing apache since is another component to maintain. Guess my Confluence Site Configurationwill be maintained with Puppet.
Bruna Griebeler
December 6, 2012
Just to reinforce Louis answer: How to Redirect Port 8090 to 80 Using Iptables
twong_atlassian
December 7, 2012
You can't bind any port <1024 in linux unless you're a priviledged user. You can either run as root (not cool), or you could run a reverse proxy to redirect traffic from 80 to somethign else (cooler).
https://confluence.atlassian.com/display/DOC/Using+Apache+with+mod_proxy
Bruna Griebeler
September 18, 2012
He Louis
I recommend you to use Apache with mod_proxy to better manage the ports to your Web Services:
Then you may use your Confluence Instance as follows:
http://www.example.com/confluence - your intended URL
OR
http://example:8090 - the hostname and port Confluence is currently installed to
OR
/confluence - the intended context path (the part after hostname and port)
Hope it helps! :)
Harry Chan
September 18, 2012
Are you running this from a user other than root? Then yes, you won't be able to access those ports and that is the problem. You need to play with the iptables and get it to redirect the ports. Setup Confluence on another port and then redirect to port 80.
Luis Mayora
September 18, 2012
Personally, I dont think I should install Apache since it is another component to maintain. I understand that this is not related to confluence and is only related to a linux environment. I dont know it is feasible to change the linux configuration to access ports below 1024.
Thougths?
Luis Mayora
September 18, 2012
Guessing i will have to automate this configuration using a puppet client on our confluence vm. No need to use root at this time :)
Nic Brough -Adaptavist-
September 18, 2012
We don't know what instructions you have followed, or what your setup is.
If it's the standalone installation, then you've got two basic options:
1. Change the port on the Tomcat to listen on port 80. You *will* need to fiddle with the security somewhat, as programs are not generally allowed to use ports below 1024 unless they are running as root.
2. Do what most of us do - whack apache on the machine and tell it to proxy http://yourmachine to http://yourlocaljira:8090
Oren Feldman
November 20, 2012
How do you set option 2? how to set the proxy?
I tried to set in proxy.conf the following but it didn't work, any hints?
<VirtualHost 127.0.0.1:80> ServerName example.com ServerAlias www.example.com ProxyRequests Off ProxyPreserveHost On <Proxy *> Order deny,allow Allow from all </Proxy> ProxyPass / http://localhost:8090/ ProxyPassReverse / http://localhost:8090/ <Location // > Order deny,allow Deny from all Allow from 127.0.0.1 </Location> </VirtualHost>
