Running Confluence over https
Jose Salinas August 23, 2011
Hello people
I would like run Confluence over https. Im running a standalone version 3.5.5.
I have a certificate provided by my Company but the extension of certificate is .cer.
According to the documentation there is not a step that explain how to do with a certificate .cer.
Any idea?
Thanks in advance.
Jose
Jeremy Largman
August 23, 2011
Hi Jose,
It's in the documentation you linked. You'll want to import your cert into the keystore (step 1, certificate option 2, number 5):
keytool -importcert -alias tomcat -keystore <MY_KEYSTORE_FILENAME> -file <MY_CERTIFICATE_FILENAME>
Jeremy
Thank you for your fast reply.
I was a little confused.
Now, I have other question. I can not find my .kesystore to replace in <MY_KEYSTORE_FILENAME>
Must .keystore be generated? Or where it should be?
Thanks.
Jose
Jeremy Largman
August 23, 2011
I believe that's under step 3:
  • On Windows: <tt>C:\Documents and Settings\\#CURRENT_USER#\.keystore</tt>
  • On OS X and UNIX-based systems: <tt>~/.keystore</tt>
Jeremy,
There is not a fille called .keystore.
I generated one executing:
"%JAVA_HOME%\bin\keytool" -genkeypair -alias tomcat -keyalg RSA
But I execute:
An exceptions is raised:
keytool error: java.lang.Exception: Public keys in reply and keystore don't match
What is wrong?
Jose
Jeremy Largman
August 23, 2011
I'm guessing that you might have imported a self-signed certificate for your domain already (ie - you've already got something with that alias?) If you google the error 'Public keys in reply and keystore don't match' you'll see a bunch of resources about it. You can consider this independently of Confluence. It's a Tomcat + SSL issue, and will have lots of solutions from other Tomcat users for the same SSL problem.
Here's one good one:
http://old.nabble.com/Unable-to-import-certificate-into-keystore-td19416557.html
Jose Salinas August 24, 2011
Jeremy,
Yes, the error was a replicated alias.
Anyway I followed all steps but I cant see Confluence over https.
Jeremy Largman
August 24, 2011
If you can still get to Confluence over http but not https, make sure you've uncommented the ssl connector in server.xml.
You are right, I can get to Confluence over http (port 8090) but no https (port 8443)
Yes, the ssl connector is enabled in server.xml
<Connector port="8443" maxHttpHeaderSize="8192"
maxThreads="150" minSpareThreads="25" maxSpareThreads="75"
enableLookups="false" disableUploadTimeout="true"
acceptCount="100" scheme="https" secure="true"
clientAuth="false" sslProtocol="TLS" SSLEnabled="true"
URIEncoding="UTF-8" keystorePass="changeit"/>
Register now
