We've reiceved an error after trying to upgrade to 7.13 coming from 7.8
Hi @Ernst,Axel ,
the upgrade fails because Confluence 7.13 is not compatible with SQL Server 2014, as you can see in the Supported Platforms page : https://confluence.atlassian.com/doc/supported-platforms-207488198.html#SupportedPlatforms-Databases
I would advise doing the SQL upgrade first to SQL Server 2016 and then trying again the upgrade.
Let me know if this helps,
--Alexis
Thanks Alexis,
I thought something like that. I'll upgrade them to an Azure SQL DB, no problem.
