I've configured Confluence 5.2.5 for an External Microsoft AD User Directory, using SSL.
On completing the config screen and clicking 'quick test' I get the 'PKIX path building failed' exception, which is identical to the one seen when there is no certificate in the keystore matching the server connected to.
However, if I run confluence with the java ssl debug flag (' -Djavax.net.debug=ssl ') then the same test succeeds, and I am able to fully sync the directory. Restarting Confluence with the debug flag removed allows synchronisation to continue to work.
Here is the solution: restart Confluence after configuring the external directory and installing the server certificate.
Nic: Have you tried manually importing the SSL cert?
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
