Script Error while fetching users who are inactive more than 90 days from confluence
SunadhRaj.Malaka June 21, 2023
hi
below is thecode :
import com.atlassian.confluence.user.ConfluenceUser
import com.atlassian.confluence.user.UserAccessor
import com.atlassian.sal.api.component.ComponentLocator
UserAccessor userAccessor = ComponentLocator.getComponent(UserAccessor)
// Get all users
List<ConfluenceUser> users = userAccessor.getUsers()
// Iterate over the users and check their last activity status
users.each { user ->
    String username = user.getName()
    Date lastActivity = user.getLastActivity()
    if (!lastActivity) {
        println("Inactive user: $username")
error: userAccessor.getUsers()
[Static type checking] - Cannot assign value of type com.atlassian.user.search.page.Pager <com.atlassian.user.User> to variable of type java.util.List <ConfluenceUser>
error: user.getLastActivity()
Cannot find matching method com.atlassian.confluence.user.ConfluenceUser#getLastActivity(). Please check if the declared type is correct and if the method exists.
Can anyone help me out on this.
Sanjen Bariki
June 21, 2023
Hi @SunadhRaj.Malaka ,
Please use the below script to find the list.
// Get all users
List<ConfluenceUser> users = userAccessor.users
String username = user.name
Date lastActivity = user.lastLogin.time
Hope this Script will help you.
Please Accept the Answer If it helps you😊
Sanjen
