Hey ![]()
I have seen that there is the possibility to define the landscape format for the pages. I am also aware of the possibility to only set landscape format for pages with odd numbers etc.
What I need though is the possibility to use the landscape format for pages with wide tables. Right now the table is just getting cut off...
Any solutions there?
Marcel
In the meantime it's possible to control the page orientation on a page level base using our Scroll Landscape / Scroll Portrait macro.
You can find further information about this in our documentation: https://help.k15t.com/scroll-pdf-exporter/latest/server/change-the-page-orientation-165944642.html
I've tried this and it doesn't seem to be working at all.
Hi @James Yau
were you using the Scroll Landscape or Portrait macro within a Confluence multi-column page layout? If so, these macros are not supported in these page formats and have to be added on page without these multi-column layouts in order to function.
If you have added these macros to a page without this formatting and the issue still persists, please can you send us an XML export for your affected content to help@k15t.com. We can then investigate this further.
Cheers, Thomas (K15t)
Hi Marcel,
we have a couple of tweaks documented in our PDF documenation on how to deal with wide tables. Please have a look at the following page: https://help.k15t.com/scroll-pdf-exporter/how-can-i-deal-with-wide-tables-75367879.html
I hope any of those workarounds helps.
Unfortunately our current library does not support setting landscape format for specific pages only (see https://k15t.jira.com/browse/EXP-374). We're currently working on a switch to a new library, that should also support this feature.
As this is a big change, I can't give you an ETA currently. Please sign up at https://k15t.jira.com/secure/Signup!default.jspa to watch, comment on or vote for this issue. We'll then send a notification for every status update.
Let me know if you have any further questions. I'll be happy to help.
Best,
Nils
