When I create a code snippet in Confluence, such as below, using the 'Code' Macro
try{ String temp = new String(); temp = "10"; System.out.println(temp); }catch(Exception e){ //Log out the exception }
Scroll office doesn't maintain the indenting or spacing. I have created a table style in my word template called Scroll Code.
Is there a something specific I need to add in the table style to make sure the Code format is preserved? It would be nice if the colour scheme is preserved but I really require that the spacing is preserved.
Hi Mike,
Syntax highlighting as well as line numbers are not yet supported. However https://k15t.jira.com/browse/OFCE-218 will take care of it.
Regarding the spacing - I know you already contacted support@k15t.com as I am the one who replied to it :)
Best,
Tobias
due to some re-org in Jira the new ticket is https://k15t.jira.com/browse/EXP-870
As far as I know this will be shipped in one of the next versions.
Best, Tobias
Hi Tobias,
In response to your email;
Attached is my output document from Scroll Office 2.5.16
I assume it is an issue with my template document. I have also attached the storage format of the confluence page. Don't know if that will help or not.
Mike
Output file: Rename from .txt to .docx (Confluence Demo Page-v21-20120917_0821.txt)
Storage Format Document: (ConfluenceDemoPageStorageFormat.txt)
