×How can I change 8443 to redirect to 443.? I have followed the documentation and its still not working.
Hey Tameika,
On the server.xml, try the following parameters:
<Server port="8000" shutdown="SHUTDOWN" debug="0"> <Service name="Tomcat-Standalone"> <Connector port="8090" connectionTimeout="20000" redirectPort="443" maxThreads="200" minSpareThreads="10" enableLookups="false" acceptCount="10" debug="0" URIEncoding="UTF-8" /> <Engine name="Standalone" defaultHost="localhost" debug="0"> <Host name="localhost" debug="0" appBase="webapps" unpackWARs="true" autoDeploy="false"> <Context path="" docBase="../confluence" debug="0" reloadable="false" useHttpOnly="true"> <!-- Logger is deprecated in Tomcat 5.5. Logging configuration for Confluence is specified in confluence/WEB-INF/classes/log4j.properties --> <Manager pathname="" /> </Context> </Host> </Engine> <!-- To run Confluence via HTTPS: * Uncomment the Connector below * Execute: %JAVA_HOME%\bin\keytool -genkey -alias tomcat -keyalg RSA (Windows) $JAVA_HOME/bin/keytool -genkey -alias tomcat -keyalg RSA (Unix) with a password value of "changeit" for both the certificate and the keystore itself. * Restart and visit https://localhost:8443/ For more info, see https://confluence.atlassian.com/display/DOC/Running+Confluence+Over+SSL+or+HTTPS --> <Connector port="443" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" maxSpareThreads="75" enableLookups="false" disableUploadTimeout="true" acceptCount="100" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" SSLEnabled="true" URIEncoding="UTF-8" keystorePass="changeit" keystoreFile="<keystoreLocation_path>"/>
The SSL will be set in Tomcat with this configuration, and not in Apache so you don't have to edit anything in mod_proxy or mod_ssl.
So if I want to set this in Apache I know I would have to set the certfile in the ssl.conf file. But then I would also have to do the following correct: <VirtualHost *:443> ServerName confluence ProxyRequests Off <Proxy *> Order deny,allow Allow from all </Proxy> #SSLEngine on #SSLProxyEngine On ProxyPreserveHost On ProxyPass "/" "https://confluence:8443/"; ProxyPassReverse "/" "https://confluence:8443"; DocumentRoot /var/www <Directory /var/www> Options -Indexes Order allow,deny Allow from all </Directory> </VirtualHost>
I am following this as documentation
https://confluence.atlassian.com/doc/running-confluence-over-ssl-or-https-161203.html
SSLEngine On errors out on Centos 7.2
mod_ssl is installed and mod_proxy
So that could be a problem because maybe SSLEngine needs be on
I have another one that I am looking at but I have the weblink at work
What documentation, and how are you doing this? There are a number of ways to do it - proxies, Tomcat settings and firewall rules are the most common, but which one are you using?
