I'm new to Postgresql and Confluence, and I'm trying to setup the database (I have the on-premise server version) by following this guide:
https://confluence.atlassian.com/doc/database-setup-for-postgresql-173244522.html
At step 2.2, it states that "Collation must also be set to utf8", but how exactly do I do that? I'm assuming it's the LC_COLLATE option, and I've tried 'UTF-8', 'UTF8', 'en_US.utf8', and 'en_US.UTF-8', none of which worked.
Any help is appreciated, thanks!
Postgres's default database template should already have these values set correctly, so you should be able to issue a "normal" create DB statement with encoding specified and get the correct collation out of the box:
CREATE DATABASE confluencedb WITH OWNER connie ENCODING 'UTF-8';
If you need to specify these manually at creatino time, you should be able to specify them like so:
CREATE DATABASE confluencedb WITH OWNER connie ENCODING 'UTF-8' LC_COLLATE='en_US.utf8' LC_CTYPE='en_US.utf8'
However if you're having to specify these and not getting it set "out of the box", my guess is the host system of your Postgres server has its locale information set to something explicitly different. If you have the locales package installed, running the locale command should tell you what LC_CTYPE and LC_COLLATE are set to by default in your host environment.
Hi Dave,
Thank you for the quick response!
I forgot to mention that I'm using Windows. I just added a tag.
I used
SHOW LC_COLLATE;
to check the locale, and I got 'English_United States.1252'. I've also tried 'English_United States.utf8' but also got the same error invalid locale name (this is the same error I got for all values listed in OP). In this case, is it ok that I use default LC_COLLATE and LC_CTYPE values? Or is there something wrong with my database setting?
Hello!
The main language of my Confluence is Russian. Most of the content is in Russian, but many English words are also used. It is necessary that the search works correctly with two languages.
Will it work out?
What values ​​should I set to LC_COLLATE = and LC_CTYPE =?
I apologize if I could not understand the previous answers.
May I suggest that @atlassian integrates the above answer in their documentation?
It would be very useful to be able to copy and paste the database creation command for Confluence from the installation docs. It's like that for Jira, so why not for Confluence, too?
Weird,
we have this DB settings:
Name | Owner | Encoding | Collate | Ctype | Access privileges
confluencedb | postgres | UTF8 | en_US.utf8 | en_US.utf8 |
And Confluence says:
The database collation 'en_US.utf8' is not supported by Confluence. You need to use 'utf-8'.
Dirk
I'm having the exact same issue when trying to upgrade confluence. I'm not new to Confluence and Postgresql, and I think this is somehow incorrect. Confluence won't start saying the collation is incorrect and should be utf-8 and not en_US.utf8. I cannot create a database with that collation. Stuck...
Have you figured it out, Dirk or someone else?
Else I'll submit a ticket.
hmm, already done by someone else: https://jira.atlassian.com/browse/CONFSERVER-58052. Maybe just move to an older version...
This is tested with Debian 12.
You can check with locale -a if your locale is present in your system. If not
locale-gen en_US.UTF-8
should create one. (In my case, de_DE.UTF-8). Alternatively,
dpkg-reconfigure locales
uses a small graphical interface to add locales. (In generation it is defined with '-': en_US.UTF-8, but in display it says: 'en_US.utf8')
Check again with locale -a and restart your database:
sudo service postgresql restart
Now you may add your database with desired locales:
CREATE DATABASE confluencedb OWNER confluenceuser ENCODING 'UTF-8' LC_COLLATE='de_DE.utf8' LC_CTYPE='de_DE.utf8' TEMPLATE template0;
which should result in a desired database:
Name | Owner | Encoding | Collate | Ctype | Access privileges | Size | Tablespace | Description
confluencedb | confluenceuser | UTF8 | de_DE.utf8 | de_DE.utf8 | | 8409 kB | pg_default |
postgres | postgres | UTF8 | C.UTF-8 | C.UTF-8 | | 8561 kB | pg_default | default administrative connection database
template0 | postgres | UTF8 | C.UTF-8 | C.UTF-8 | =c/postgres +| 8409 kB | pg_default | unmodifiable empty database
| | | | | postgres=CTc/postgres | | |
template1 | postgres | UTF8 | C.UTF-8 | C.UTF-8 | =c/postgres +| 8561 kB | pg_default | default template for new databases
(4 rows)
Any *.utf8 will store its data in UTF8 encoding, but what is the difference between the locale in the first position? Here, e.g. the difference between "C.utf8" and "en_US.utf8":
The differences are in:
int_curr_symbol
currency_symbol
mon_decimal_point
mon_thousands_sep
mon_grouping
negative_sign
int_frac_digits
frac_digits
p_cs_precedes
p_sep_by_space
n_cs_precedes
n_sep_by_space
p_sign_posn
n_sign_posn
crncystr
thousands_sep
grouping
d_t_fmt
d_fmt
t_fmt
yesexpr
noexpr
Here are also some more detailed explanations regarding the locale which can be configured during the database cluster generation using initdb:
https://www.postgresql.org/docs/current/locale.html
See: 24.1.2. Behavior
The drawback of using locales other than C
or POSIX
in PostgreSQL is its performance impact. It slows character handling and prevents ordinary indexes from being used by LIKE
. For this reason use locales only if you actually need them.
