×Hello,
I tried to implement an Excel file which is located and continously updated on SharePoint. Therefore I used the "SharePoint Document" macro, with the option "response view" activated. This is the result:
With the option "fixed view" activated it is nearly the same result, just that the preview is now in the top left corner, same size.
Is this a known issue or bug?
Thanks in advance
Hi Nils,
It looks like you are using the App SharePoint Connector for Confluence form the Marketplace. I'm working for the vendor of said app.
What you are experiencing here looks unusual at least. I suggest to get in touch with our friendly support team, they do miracles in analyzing situations like that :)
Let me know if I can help you out.
Cheers, David
Co-Head of Products
