Showing jira issues status that created in conflunce from a confiform in confiform table view
ebrahim rezaian May 24, 2023
Hello
I have a confiform form witch creates issues in jira. i want to show status of created issues in confiform table view. what formula should i set in "ConfiForms IFTTT Integration Rules" in "Parameters to set on the entry" to reach this?
thank you for your help
ebrahim rezaian May 25, 2023
@Alex Medved _ConfiForms_
Hello Alex
Thanks a lot for your countless helps.
in "ConfiForms IFTTT Integration Rules" in "Parameters to set on the entry" i should set jira status. but how can i find documentation? or could you say to me how should i write in "Parameters to set on the entry"to reach jira status.
Status is not returned back when Jira issue is created, only the key
So, you better save it back to Jira issue field and then access the status from there as shown on https://wiki.vertuna.com/display/CONFIFORMS/Accessing+Jira+issue+fields+directly+from+ConfiForms+using+Jira+issue+field
