We are using the blog function of confluence and we were wondering if it was possible to have a ‘sticky’ to keep certain post at the top of the page?
thx in advance!
If you are using the {forum} macro from Adaptavist it has a sticky function for the forum display.
Hallo Miko
Confluence doesn't have a "sticky post" feature. But you can add a label to a blog post, such as "sticky", and then use the Blog Posts macro on a page, to show only the post(s) labelled with that label:
https://confluence.atlassian.com/display/DOC/Blog+Posts+Macro
I hope this helps!
Cheers, Sarah
