hi, i am Korean, and i'm using Survey and Vote Macros in Confluence.
i think this is good to survey the opinion collection with team members.
but, whenever i try to export Excel file about the survey result, language is broken in file.
i think this plug-in is not support Korean Language in confluence web.
please, check the issue. thank you. i hope using the export excel file about survey result.
Hi Junhong,
would it be possible to track this on this plugins issuetracker: https://github.com/drohne1673/confluence-survey-plugin/issues
I had such a request before: https://github.com/drohne1673/confluence-survey-plugin/issues/43. I am not sure it was you, but it was the exact same problem and it was not a problem of this plugin.
If you have resolved it til now, it would be great if you can flag a answer here so others can find it
thanks
Frank
