×Hello
I have the following problem, there is no synchronization of users from Jira to Confluence, although I have not made any changes
Maybe you can help me how to do it, or specifically in which server log I will find the error it will tell me.
Hi @keti burjanadze ,
please check the log file in your CONFLUENCE_HOME_FOLDER/logs/atlassian-confluence.log
If you need support on that please attach the error retrieved from that file.
Hope this helps,
Fabio
hi
thanks for answer :)
I found the following errors in the logs
And when I do the synchronization manually the log writes the following warning
We tried Disable and it did not help, we did not try to create a new one
Please, disable the existing directory and create a new one with the same setup.
@Fabio Racobaldo _Catworkx_ I created a new directory and solved the problem, thanks for the help :)
