System Error In Confluence
Cormant Systems Administrator
Below is the error that received by opening the Url
Cause
com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.IllegalStateException: Spring Application context has not been set
at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149)
caused by: java.lang.IllegalStateException: Spring Application context has not been set
at com.atlassian.spring.container.SpringContainerContext.getComponent(SpringContainerContext.java:48)
Fabian Lim
Hi @Cormant Systems Administrator
I recommend you open a ticket with atlassian support if you are still experiencing this issue: https://support.atlassian.com/contact/#/
Regards
