Sign up Log in
System Error after upgrading to 7.13.2
Information Technology
November 21, 2021
After attempting to upgrade feomm 7.11.2 to 7.13.2, get this error when Confluence starts.
Cause
java.lang.RuntimeException: Error rendering template for decorator root
    at com.atlassian.confluence.setup.velocity.ApplyDecoratorDirective.render(ApplyDecoratorDirective.java:162)
caused by: java.lang.RuntimeException: Error rendering template for decorator global
caused by: org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getRenderedLayoutForGlobal' in class com.refinedwiki.confluence.plugins.theme.original.helpers.ThemeHelper threw exception java.lang.NullPointerException at originaltheme/templates/decorators/global.vmd[line 79, column 74]
    at org.apache.velocity.runtime.parser.node.ASTMethod.handleInvocationException(ASTMethod.java:342)
caused by: java.lang.NullPointerException
    at com.refinedwiki.confluence.plugins.theme.original.helpers.ThemeHelper.getRenderedLayoutForGlobal(ThemeHelper.java:805)
Note: Cannot access Confluence web at all to uninstall any apps or templates.
Any suggestions?
Medhat Ahmed
November 22, 2021
Dear @Information Technology
if you want to uninstall addon without web portal all addons are stored in your home directory you will find a directory named "plugins" then "installed plugins" please stop confluence first then you can remove addons from their, kindly take a backup from this directory before moving it then try to start confluence again and it will start without any addons.
I think you should review your server.xml configurations.
please accept my answer if it helps you on your issue.
Best Regards,
Medhat
