System Error when configuring LDAP user directory with AD
Oren Feldman
November 11, 2012
Hello Everyone,
I'm quite new with confluance and I'm not sure what I'm doing wrong.
When I'm trying to set up Active directory in the user directories, I provide all the mandatories details and then when clicking "Save and Test" I get "System Error" the stack trace is empty and I get this error very fast, it doens't seems like my server is trying to communicate with my active directory servers at all.
I read here and on line, trying to search for this problem but is seems like it should be very straight forward settings, but I still get this error with no details to troubleshoot.
Any tips?
LuizA
November 11, 2012
Hello There,
As a first approach I would suggest you to double-check the settings of your Active Directory in the LDAP configuration at Confluence, you can use this guide to performing this checking:
https://confluence.atlassian.com/display/DOC/Connecting+to+an+LDAP+Directory
If you still experience the error I would like to suggest you to raise a support ticket at our support.atlassian.com and attach your latest support zip for a review, so we can perform a better investigation and find the root cause of this behaviour to you.
I hope this helps.
Best Regards,
LJ.
