Tables Use ASCII Sort Order
Jason Tolotta
June 17, 2020
The sort mechanism of the table is using ASCII sort order.
This causes all the uppercase terms to be first before the lowercase terms, i.e. "FOO" will be ordered before "bar" when clicking the sort option "Sort column A to Z".
Andrey Khaneev _StiltSoft_
June 17, 2020
That's true. Also, it is not working correctly with umlaut characters. But if the table is wrapped with the Table Filter macro, then sorting works correctly.
