Template vs Blueprint
Dmitry Dm
Can someone shed some light, please, on what the difference is between a page template (classic Confluence functionality) and a blueprint? Seems to be the same thing.
11 votes
Prateek Bansal March 8, 2015
This is the difference based on my experience
Blueprint
Template
Title can be pre-populated For e.g. dynamic dates in minutes page
Title is Blank
UX Wrapper to pre-populate content dynamically in the page and have macros
No UX Wrapper, but can have pre-written/designed content and end user macros
Needs more development efforts
Needs less development effort. Faster to create.
Creates Index/Report page if Page Properties are included in the blueprint
Does not create any index
5 votes
Stephan Sutter
Our company is ISO9001:2015 certified and we started to use Confluence in 2013. We had the Vision to do all our documents within Confluence: contracts, offers, specifications, etc. But our customers still want Word documents and PDFs. So we had to find a way to get all your Word Templates into Confluence. With Confluence templates you can do only one page templates and that was a Show stopper. Blueprints can only be improved by a very small number of employees and that is not collaboration! So in the beginning we used the Plugin Copy Page Tree. It worked, but we were looking for a better way.
So we decided to write our own plugin called Page Tree Creator. The following table describes how we see the difference between the solutions.
If you want to see our Page Tree Creator in action, checkout our live examples under this link:
https://focuspro.eps.ch/display/PEPSMarktExample/Marketplace+Examples
Feature / FunctionPage Tree CreatorCopy Page TreeBlueprintsTemplate
Page Trees are supportedticktickminusminus
Search & Replace in Page Titletickticktickminus
Search & Replace in Page Contenttickminus
tick
minus
Search & Replace in Macro Parameterstickminusminusminus
Search & Replace in Label Fieldstickminusminusminus
Copy attachmentsticktickminusminus
Default Tags (variables, e.g. current user, template Version,...) tick minus tick tick
No Programming Skills needed, so everybody can improve templatesticktickminustick
Create Index / Report page based on Page Propertiestickminustickminus
Button with source and destination link to create new Page / Page Tree
tickminustickminus
Cascade Creation of Multi-Page Treestickminusminusminus
No need of Administration Permisson for the design of Page Tree Templatesticktickminusminus
Page restrications are copiedticktickminusminus
Standard Confluence links behind Buttons: Renaming and rearrangement of template pages works like everywhere in Confluence
tickminusminusminus
Tag Markers can be configuredtickminusminusminus
Typed Input Fields (user picker is done, date, time, etc. will follow)( tick )minustickminus
Copy published Comala Pages
ticktickminusminus
Copy Page Tree without Search & Replaceticktickminusminus
Create Space and copy Page Tree: Use our plugin Space Tree Creator
( tick )minusminusminus
Internationalization of Page Trees
tick, build Page Tree per languagetick, build Page Tree per languageminusminus
Internationalization of one Pagetick, build a Page per languagetick, build a Page per languageticktick
Stephan
kobull June 12, 2017
This looks awesome. Thanks for making this. I was about to have to create this, or a version of it. Do you have developer documentation on how to use and extend this?
Charisma Riley
@Stephan Sutter I love the concept behind your add-on! I noticed, however, that the Cloud version is quite distinctly nerfed compared to the Server versions. . . so according to the features you list above (which is way more complete/clear than the feature sets explained here, which ones apply to the state of the Cloud version today? What features does it currently have compared to the native Cloud template editor? (If I am going to make a recommendation to my group, I need to have this information.)
Thank you, in advance, sir!
Brittany Walker July 2, 2014
One difference I have noticed is that with Blueprints, you can specify what you want the title of the page to be and add variables. Ex. if you create a page with the Meeting Notes blueprint, your page is automatically titled " Todaysdate Meeting Notes."
As far as I know, you can't do that with templates. When you create a new page from a template, you have to manually enter the name of the new page:
Stefan Ernst
templates are somewhat limited, with blueprints you can build a fully customizable wizard for your Jira pages. Look at what the polls plugin does with blueprints
https://marketplace.atlassian.com/plugins/com.simplenia.confluence.plugins.polls
Charisma Riley
Sorry to re-open an old thread, but I am still looking for this information, especially for Cloud. What are the differences between the Templates we can make with the Template Editor vs. Blueprints?
Malik Mangier December 6, 2019
"A blueprint is a page template with added functionality to help you create, manage and organize content in Confluence"; From https://confluence.atlassian.com/doc/page-templates-296093785.html , but that holds for Cloud as well.
I'd say start with Templates you can make with the Template Editor, if you run into any limitation in terms of customization/automation then start looking at blueprints
Timothy
August 26, 2013
Daniel Borcherding
August 26, 2013
TLDR; A blueprint is a template with extra sugar.
Like # people like this
Dmitry Dm
It says in the doc that "A blueprint is a page template with added functionality to help you create, manage and organise content in Confluence.". Can you, please, give an example of such functionality? So far I see a blueprint as just a large template that can include several simple page templates... Am I right?
JRR January 20, 2015
Yes, concrete examples would help me understand that statement as well!
LUC FILION June 3, 2014
I invite you to look at the Gaia for JIRA plugin, which basically allow to create new spaces based on a template space. It has got several templates included, and it includes blueprints as well. This allows basically to have a broad set of Confluence pages, and blueprints. So anyone can start a new project based on an predefined environment. Pretty neat.
