×The Excel macro has settings to limit how many rows and columns are rendered in the finished display. If a spreadsheet is rendered that has anything in a column or row it is rendered regardless of the limitations. Example:
A sheet is uploaded that has visible data in 15 columns and 60 rows with formulas to display data in the remaining rows up to row 500. The macro is configured to display 10 columns and 60 rows.
Once the page is saved all 15 columns and 500 rows are displayed; why?
I had the exact same issue as described by Rick. This is how I got it to work.
Thanks, this worked for me.
Thanks, it works.
I have tried it a different way, I didn't delete the excel file, just opened to edit with excel (companion app needed), and uploaded after a save (without any change). It works too.
Worked for me!
In 7.19.5 you still can't change the rows/columns without deleting the file, making the change and reattaching the file. But the latter does work in this version. Thank you for the tip. Too bad Atlassian can't be bothered to fix it.
Thank you for this, finally a solution that works! (7.19.5)
This was driving me absolutely crazy, wish it was more intuitive.
And the prize for the "Most Intuitive and Straightforward User Experience" goes to setting the number of rows to be displayed. Thanks HD Nguyen. your suggestion still works in June 2024...
Update to the original question; the problem appears to only be an issue when attempting to change the settings for an already established Excel macro. For instance:
1. Upload a spreadsheet
2. Insert a macro displaying 50 rows and 12 columns
3. Update macro to display 60 rows and 12 columns
Notice that the number of displayed rows doesn't change. I tried this with Chrome, Firefox, and IE; no difference. I also see that it doesn't matter if the macro is deleted, the page saved without the macro, and a new macro inserted with the new settings. Once a macro is established on a given page it cannot be changed to display a different number of rows or columns (increasing or decreasing the number doesn't matter).
