Traffic stats for Confluence
Bob Nicholson August 20, 2012
I was hoping to find a way to track page traffic in Confluence (without installing macros on eahc page). The installation is behind a firewell, so we can't use Goggle Analytics.
I found a link to a plugin called Traffic Stats Plugin, but the page is missing:
https://developer.atlassian.com/display/DEVNET/Traffic+Stats+Plugin
Any idea what happened to the plugin? Is there another way to track traffic?
Kay Brown
August 20, 2012
Ah - thank you. From the initial blurb, I thought this required a macro to be installed on each page I wanted to track. I see now that I was mistaken, and this does what I need.
Midori
November 4, 2014
You haven't gone into details about what you'd use this information for.
  1. If it is for full-blown analytics, then besides Kay's answer, you should also check out the Viewtracker Plugin.
  2. If it is primarily to find the "abandoned" pages that no-one views anymore, then the Archiving Plugin, particularly its page view tracking feature is your friend.
David at David Simpson Apps
Hi Bob,
Just because you're behind a firewall, it doesn't necessarily mean you can't use Google Analytics. Do your client browsers have access to the internet? if so, you can still track usage with Google Analytics.
If you want to embed Google Analytics reports into Confluence with Google Analytics for Confluence plugin, then you'd have to open up the firewall for your Confluence server (only) to communicate with www.google-analytics.com
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
