Sign up Log in
Troubles with Instalation of "Questions for Confluence" Plugin
admin_ruben December 14, 2015
Hi everyone,
I yesterday purchased the Questions for Confluence Plug-In and immediately after entering the key got into troubles.
Namely, it is obvious that the installation of the Question plugin did not integrate with the existing Confluence instance.
  • There are two occurences of the "People" button in the header menu:
    image2015-12-15 10:4:37.png
  •  On the side menu in the Confluence Administration view there are duplicate instances of several menu items. Ex: Purchased add-ons or Global Permissions.
    image2015-12-15 10:8:4.png
  • The Create ->"Ask a question" takes me to Page Not Found page.
I am even unable to Disable nor to Uninstal the plugin via the Manage add-ons Panel. I get the following log messages:
Failed to uninstall add-on Questions for Confluence Plugin (com.atlassian.confluence.plugins.confluence-questions version 2.4.4)
Failed to disable add-on Questions for Confluence Plugin (com.atlassian.confluence.plugins.confluence-questions)
Can anyone help or share experiences?
Thank you in advance,
Ruben N
admin_ruben December 16, 2015
Hi Vasiliy,
The Questions plugin version 2.4.4 and the Confluence 5.8.4 are compatible. Anyway, we managed to solve the problem by simply... restarting Confluence. After that everything seems to get into place.
Thanks anyway!
Vasiliy Zverev
December 14, 2015
First of all check where plugin version is compatible to Confluence version.
