URL Move for Confluenc
Cynthia Fehr
September 1, 2015
We are moving the Confluence server to a new location which will force us to change the URL of the server. We have a lot of URLs in Confluence that refer to the old server.
Is there a recommended way of moving the URLS to the new server?
Thank-you,
Cynthia
Mallmann
September 2, 2015
Hi Cynthia,
In case you want to replace hard links of the instance I recommend you to follow this guide after changing the base URL as per Luiz comment: https://confluence.atlassian.com/display/CONFKB/How+Do+I+replace+all+'hard'+links+to+my+old+Base+URL
I hope it helps,
Eduardo
Luiz Maia
September 1, 2015
Hi Cynthia,
You can follow the instructions from this guide to reconfigure the Confluence base URL. This should do the trick.
Thanks.
LM
Cynthia Fehr
September 4, 2015
Hello @Eduardo Mallmann...I think the guide you are linking to is what I'm looking for but I can't click on it.  Can you please check the link?
Mallmann
September 4, 2015
Hello Cynthia, I've just edited my answer, I hope you can access the guide now. :)
Cynthia Fehr
September 9, 2015
Thank-you!
Register now
