Unable to select text for copy from a published code block macro
Jon Kovalik January 23, 2023
I'm running on Confluence DC 7.19.3 and published a page with a code block using the code block macro.  While in a published state, I am unable to select text in the code block to copy and paste (ie to a terminal).   The block essentially appears to be an image that doesn't allow selecting of any text.  My workaround is to edit the page and select the code, but that kind of defeats the purpose.
I know this is possible as another instance for which I do not administer, can perform this functionality.  Is there a configuration setting to change this behavior?
Mirek
Hi @Jon Kovalik ,
Not quite sure if this is something than can be configured in any way. Seems more like a bug than a feature. Are you able to reproduce this on a different browsers? Is someone else also having this problem? Does is relate to specific page or code that you paste?
Jon Kovalik January 27, 2023
This occurs in multiple browsers (seems to be unique to our instance of confluence).  Are users are seeing the same behavior and it occurs for any instance of using a code block macro.
Mirek
Do you see any errors in the browser "Developer tools" when you load a page that contains Code Block macro?
https://confluence.atlassian.com/kb/generating-har-files-and-analyzing-web-requests-720420612.html
Basically we would have to analyze web requests and make sure that page is fully loading correctly without any errors...
If you find anything suspicious please share - it might lead us towards resolution
No errors being reported, but 56 warnings that are mostly tagged with DEPRECATED.  I'll take a look through the details, but nothing obvious.
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
