Universal Plugin Manager 2.19.1 not showing plugins
Evan Overby August 4, 2015
I recently updated to UPM 2.19.1 while on Confluence version 5.8.4.  Now when I go to Manage add-ons nothing is listed and I cannot can't change any of the fields.  So I upgraded to 5.8.6 and still get the same thing.
Evan Overby November 6, 2015
Just to update this issue, I was able to follow this article and provide a workaround:
https://confluence.atlassian.com/display/CONFKB/Manage+add-ons+menu+does+not+populate+after+upgrading+the+Universal+Plugin+Manager
I found that the plugin causing issue is the English (US) Language Pack.  I have updated to 5.8.6 to match my Confluence version but still no luck.
To get into manage plugins, I can change my language under my profile to English (UK) and everything works perfectly.
I will remove the plugin and install fresh after a Confluence service restart.
Septa Cahyadiputra
August 4, 2015
Hi Evan,
First and foremost, we need to exclude corrupted plugin cache as the cause of your issue by clearing plugin cache as describe here:
https://confluence.atlassian.com/display/CONFKB/How+to+Clear+Confluence+Plugins+Cache
If the issue persist, please check the logs and see if there are any error mentioned. If you can post it here (publicly accessible) then feel free. If you can't, you should create a support ticket with Atlassian so our support engineer could review your logs (not accessible publicly) in confident.
Septa Cahyadiputra
