Unknown macro: 'gliffy' not visible
Deepika December 17, 2019 edited
Unknown macro: 'gliffy' not visible CAn anyone tell what will be the solution to thisSHIVAM.PNG
John Almeida
December 17, 2019
Hi, it appears that you no longer have Gliffy installed onto your instance. Can you please check to make sure that the Gliffy app is properly installed into your Confluence instance?
If it is, I would recommend doing a quick re-install to make sure that it is installed properly. If you continue to run into issues, please contact the Gliffy Support team at support@gliffy.com to help you troubleshoot.
-John
