Hi all,
Just performed upgrade from 3.5.17 to 5.0.3 (manually).
Based on the logs, encountered an error while pointing 5.0.3 application to database:
1.)
caused by: org.springframework.jdbc.BadSqlGrammarException: Hibernate operation: Could not execute query; bad SQL grammar []; nested exception is java.sql.SQLSyntaxErrorException: ORA-00904: "SPACE0_"."SPACESTATUS": invalid identifier
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:97)
caused by: java.sql.SQLSyntaxErrorException: ORA-00904: "SPACE0_"."SPACESTATUS": invalid identifier
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:447)
2.)
2014-09-01 15:57:11,649 ERROR [http-8081-3] [[Standalone].[localhost].[/].[file-server]] log Servlet.service() for servlet file-server threw exception
org.springframework.jdbc.BadSqlGrammarException: Hibernate operation: could not load: [com.atlassian.confluence.core.ContentEntityObject#51905073]; bad SQL grammar []; nested exception is java.sql.SQLSyntaxErrorException: ORA-00904: "CONTENTENT1_"."PLUGINVER": invalid identifier
What should I do regarding the errors that I encountered?
Thanks in advace.
Hi Hanshin,
This issue could be related with a bug mentioned here: https://jira.atlassian.com/browse/CONF-31333
Please try the mentioned knowledge base and see how it goes:
https://confluence.atlassian.com/pages/viewpage.action?pageId=419004803
Also make sure that your license is valid and applicable for 5.0.3. If the above information doesn't help, we highly recommend you to contact our support team through https://support.atlassian.com/to further investigate your issue by reviewing your complete log confidentially.
Hope it helps.
Septa Cahyadiputra
Hi Septa, My apologies for the late reply. Btw, thanks to your reply I performed my upgrade from v3.5.17 to v5.0.3 successfully. But when I tried upgrading to v5.0.3 to v5.5.2, I encountered this error: Table 'LINKS' has more than one primary key I tried again to apply the solution that you said but to no avail the error still occurs and the upgrade is not successful. What should I do? Thanks in advance.
Confidently manage users, permissions, and content in Confluence. This self-paced learning path helps admins streamline collaboration, improve user experience, and apply the best practices to get the most out of Confluence in any cloud environment.
Start Learning Now
