Hi all,
I'm trying to create a new user macro to achieve following:
My user macro includes the jiraissues macro.
If I include only one JIRA issue into a page, then my macro works fine. But if I try to include more instances of my macro (more jira issues) into the same page, then only the very first JIRA issue is included and it is repeated many times.
Here is the source of my user macro:
## Macro title: BRS JIRA követelmény
## Macro has a body: N
## Body processing: Rendered
## Output: XHTML
## Developed by: Pecsenye László
## Date created: 30/07/2019
## @param reqId:title=JIRA Req ID|type=string|required=true|desc=JIRA Req ID
<style>
.brs-jira-req .jira-issues table tbody tr th {
display: none;
.brs-jira-req .jira-issues table tbody tr.rowNormal td.jira-macro-table-underline-pdfexport {
display: inline-block;
</style>
<div class="brs-jira-req">
<ac:structured-macro ac:name="jiraissues" ac:schema-version="1" ac:macro-id="$!paramreqId">
<ac:parameter ac:name="url">http://localhost:8080/browse/?jql=key%20%3D%20$!paramreqId</ac:parameter>
<ac:parameter ac:name="columns">key;summary;description</ac:parameter>
<ac:parameter ac:name="renderMode">static</ac:parameter>
</ac:structured-macro>
</div>
Any ideas?
Thanks in advance,
LAci
what Jira & Confluence version are you using?
I ask because I cannot recognize the macro you're referencing.
When I embed a Jira macro in Confluence the storage format looks like:
<ac:structured-macro ac:macro-id="55ff4992-013f-4f42-8d4d-00f6e0fdf217" ac:name="jira" ac:schema-version="1">
<ac:parameter ac:name="server">My Jira Server Name</ac:parameter>
<ac:parameter ac:name="serverId">the server id</ac:parameter>
<ac:parameter ac:name="key">JIRA-1234</ac:parameter>
or as a table
<ac:structured-macro ac:macro-id="6cb4b3ad-e0e6-4fac-86a3-dd6269dd4398" ac:name="jira" ac:schema-version="1">
<ac:parameter ac:name="columns">key,summary,description</ac:parameter>
<ac:parameter ac:name="maximumIssues">5</ac:parameter>
<ac:parameter ac:name="jqlQuery">project = JIRA AND assignee = "abc" AND NOT resolution IS EMPTY ORDER BY updated </ac:parameter>
It seems to me, that a non-standard macro is used. If this is the case please contact the macro app vendor.
Best
JP
Hi again,
pretty sure you're using an older version of Jira and/or Confluence.
I'll try your macro with the latest versions.
Best
JP
Hello JP,
Currently I'm using the evaluation version (local server) of Confluence 6.15.7 + JIRA v8.3.0#803001).
Anyway, I rewrote my embed code according to your 2nd example, and now it is working as expected.
Thank you for your quick help.
BR,
LAci
