Using HTML macro in FireFox doesn't get rendered
hemanth acharya February 3, 2015
I am using a HTML macro, which gets rendered in Chome and IE but doesn't get shown up in Firefox. My version is 31.3. Anything that I have to enable?
Hemanth
Alex Medved _ConfiForms_
HTML macro in Firefox just does not render anything at all, or just some content you have? Have you tried with a simple content? It might be that your HTML macro content just brakes the rendering in Firefox... but is is not about HTML macro, but more about the content you want to render
hemanth acharya February 4, 2015
I have tried simple content, but in the page which is not displaying has a link which got a target="_blank" attribute in the href element,. basically the document link has to open in an separate page.
"simple" content is displaying correctly?
hemanth acharya February 5, 2015
Yes it is.
Obviously you need to cleanup/fix the content you are trying to include with HTML macro
But it works in Chrome and IE with whatever content I have
hemanth acharya February 10, 2015
Got the reason to it, placing a "Tip" macro inside "Section" macro doesn't work in FF. Do you know why is it so? There are no errors in the backend as well.
Hard to say without seeing it, need to debug... No javascript errors inside the dev console?
No, I just verified, there are no errors in the console as well. The section div gets disabled once I place the "Tip" macro. Can you try from your end?
