Sign up Log in
Using LDAP and IT changed group names, how to update Confluence
Del Jensen
January 8, 2016
We use LDAP for user authentication and also for group access to various spaces.  When the group names change in LDAP, Confluence sees the new group name but the spaces and pages are still set to the old name.  How do we find all the old names so we can get them changed to the new name?
Tim Eddelbüttel
January 8, 2016
Hello Delmar,
renaming groups are not supported in Confluence and JIRA.
https://jira.atlassian.com/browse/CONF-13571
https://jira.atlassian.com/browse/JRA-1391
To search for the group usage look at the database or database backup:
  • spacepermissions for space restrictions
  • content_perm for page restictions
  • cwd_membership and cwd_group for the user / group memberships
  • ao_950dc3_tc_subcals_priv_grp if you use Team Calendar
I think that are the relevant tables.
I suggest you to manage your groups in Confluence if you can't control changes within the LDAP server.
Tim
Del Jensen
January 8, 2016
Thank you, Tim. Is there a way to list the unknown groups of pages/spaces? Then would be able to adjust them instead of waiting for users to call that they have lost access.
Tim Eddelbüttel
January 8, 2016
I think only a database backup will assist you with that. Or you import the dump to a Confluence test server and prevent the LDAP sync to look at GUI level.
Matthias Fleschütz
Hi there
is that still an issue? I can not acces the CONF-issue-link anymore?
best
Del Jensen
August 21, 2018
I'm not able to access the CONF link either.  The JIRA one does though.
Regards
Upcoming Confluence Events
