Using a #Hashtag
Ole Kristensen
We're starting introducing the usage of #hashtag in Status Updates. Where do I find documentation? For example it seems that #wiki is not working but all other labels I've tried so far works. Any clues?
Deleted user June 4, 2012
Thanks for the tip :) Well if it is not in the official documentation, then I guess it isn't documented. Both the internal search engine and Google should find it if it was there. Then it is not so uncommon for software to have undocumented features.
Is wiki defined as a label? If it is labels that works with the hashtags I guess you need to define the label and apply it.
See inside
