Using lock file in confluence
Denys Kovalenko
December 17, 2013
Does Confluence has lock file as in JIRA?
Aseem Parikh
December 19, 2013
Do you mean a lock file like one that's created once the Tomcat process is running?
If so, then yes. There should be a .pid file under the "work" directory.
Denys Kovalenko
December 19, 2013
But our Confluence doesn't hahe one in working directory.
Do you know how to activate it?
Aseem Parikh
December 19, 2013
You can set CATALINA_ID in bin/setenv.sh although I suspect it may already be set. It will take effect when you restart Confluence
Denys Kovalenko
December 19, 2013
thanks you a lot.
i'm realy appreciate you help.
Aseem Parikh
December 19, 2013
No problem at all. Always happy to help!
atlassian, confluence, marketing templates, confluence templates, marketing project management, content strategy, campaign planning, marketing collaboration, confluence for marketers, atlassian learning, marketing workflows, confluence best practices
5 must-use templates for Marketing teams (from a Confluence Marketer!) 👩🏻‍🎨
Read more 📚
