Using string replacement ($& and $+) with findReplaceRegex (Confluence CLI tool)
Maarten van Hees June 10, 2012
Hello!
I've been using CLI for a few days now and it has greatly sped up the wiki migration i'm doing. Today i've been doing a lot of findReplace and findReplaceRegex to replace common things throughout very similiar articles, but i ran into a little problem wich i can't seem to figure out.
What i'm trying to achieve is this: i need to find strings that start with '@' and have all capital letters and then, with the match, i want to put <span class='myclass'> </span> around it to get some simple syntax highlighting. I'm not a big expert on regular expressions, but from what i can remember shouldn't it be possible to use string replacement on the right hand part of the findReplaceRegex action call parameter in order to re-use the matched string?
I've found this example at the documentation:
--findReplaceRegex "(a )(test)(.*):\$1\$3#\$2#"
Which seems to be doing something similiar to what i want, using the matched strings again to replace the existing ones. However, i can't get this to work. When i do it like this it just prints \$1\$3#\$2# as string in my article.
Any idea if it's possible to get it working? Would again be a great time saver. This is what i have so far:
--findReplaceRegex "(@)([A-Z):\$&"
Thanks in advance!
Bob Swift
June 10, 2012
  1. It helps a lot to get your regex working using this tool: http://www.regexplanet.com/advanced/java/index.html
  2. You need to watch out for special characters (command line and regex) - it can get confusing when you have to escape things and it depends on your OS what needs to be escaped (the example \$ is an escaped $ on unix)
  3. Quick look at your regex shows a few problems
    1. Don't you want [A-Z]* ? You are missing the closing ] and the * (0 or more characters)
    2. You need $1 on the replace
    3. I suspect you need some like:
      (@[A-Z]*):some text\$1some other text
Maarten van Hees June 13, 2012
Thanks for your answer, i've checked it out and i managed to get it working! Seems i wasn't far off, i kept using \$1 but it started working when i stopped using the backslash. This works for me:
--findReplaceRegex "(@[A-Z0-9]*):<span class='quaestor_syntax'>$1</span>"
Thanks again for your help!
Bob Swift
June 13, 2012
Good, for Windows, you don't need to escape the $ like for unix.
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
