Using template variables
sternpost
Hello!
I put in top of template "my var1 = $myvar1". Then when i need using this variable in template's text on page i just print "$myvar1" and it highlight with green color.
It confuses me that when creating a page from a template, the Page Template Wizard in step 2 displays as many input fields for the value of the variable as it appears in the text. Yes, duplicate ones are filled in parallel, but I would like to set it once and that's it.
Am i right using template variable?
Stephan Sutter
Hi @sternpost
Our Confluence App Page Tree Creator shows the value only once per creation, even the value is used in different pages within the page tree.
You can find the Page Tree Creator on the Marketplace.
Stephan (PM of EPS Software Engineering AG, the vendor of the Page Tree Creator)
Davin Studer
December 22, 2020
Unfortunately, there is no way to only have it show once in the wizard. However it will fill the same value for each instance of that template variable.
If you want to to do it the way you are wanting you would need to create a blueprint instead of a template.
Register today
