View file macros doesn't work
Sergey Kondakov October 26, 2021
I've configuration of Confluence server under HTTPS with NGINX. Unfortunately I can't view any docs by clicking on them. I see that browser try to open modal window and it show progress circle and that's all. At trace of browser I see only alive requests to browser. Please advise what should I do to fix it.
Kishan Sharma
HI @Sergey Kondakov Can you please check if "Office Connector" plugin is enabled ?
Sergey Kondakov November 1, 2021
Atlassian no longer offers personal support for Starter Licenses.
Kishan Sharma
Ah yes, server Starter Licenses are supported exclusively through the Atlassian Community which is also staffed with atlassian support engineers who can help for such issues. Hopefully someone gets back to you on this.
I try it but I have Server release and faced with some issues. Could advise which path should be used to register my ticket.
Yes, for all attachments, I can only download it through web browser. When I try open it at confluence interface I see that nothing happens, only progress ring is rotating.
Kishan Sharma
Ah ok, this is something that need troubleshooting by collecting HAR file to see if the requests are completing or stuck. I would suggest raising a support ticket to Atlassian Support for help.
So, have you any idea about this issue? It's still completely desn't work.
Kishan Sharma
Is this happening for all attachment types or any specific type of files?
Hi. Plugins was enabled. I've check it earlier.
Kishan Sharma
Great that you have got it working :)
SERVER
VERSION
7.14.0
Help us plant more trees
