Hi. I'm getting an error when using viewtracker on confluence 5. I have an older version of confluence(version 3) and viewtracker is working fine. What I did was install the macro and registered it after.
The error message I'm getting this:
Error rendering macro 'viewtracker' : com/opensymphony/webwork/ServletActionContext
Thanks.
Hello Kristine,
View tracker appears to be a thrid party plugin. There may be some subject matter experts lurking on the forum, but I thinkit might be best to start a support request with the company that developed the plugin. A link to thier marketplace support page is below.
This is likely going to require a set of logs available from a support.zip
Hi Kristine
Thanks for reporting this issue! The problem should be fixed in version 3.0.1 released today.
Cheers
Remo
Want to leave your mark on Confluence? One winner will have their whiteboard design added into Confluence for all users to access! This is your chance to showcase your creativity, help others, and gain recognition in the Confluence community.
Share your template today!Online forums and learning are now in one easy-to-use experience.
