When will an upgrade come for Content Survey and Reporting pluging (knowledge base)?
Jorge
October 17, 2013
We really like to use the Content Survey and Reporting plugin here: https://marketplace.atlassian.com/plugins/confluence.plugins.knowledgebase.survey
Also we are desperatly wanting to move to Confluence 5.3.
Does anybody know if an upgrade is planned? Approximately for when?
Thanks!!
Jorge
November 11, 2013
no update on this question, i will close it and cross my fingers for a quick update
Alejandro Conde Carrillo
October 24, 2013
Yes, there are currently some people working on it but unfortunately I do not have an estimated time yet. I will ping this question to the team working on it so they can update with more information.
Jorge
October 31, 2013
Alex, no answers yet. Any update?
Noelle Steele
December 10, 2013
I've seen this plugin working in Atlassian's Confluence on this page: https://confluence.atlassian.com/pages/viewpage.action?pageId=345637394.
They are using Confluence 5.4. How did they get the plugin to work? We recently set up a dev server upgraded to 5.4 and we see "Error rendering macro 'kbsurvey'" when using the macro and a system error when trying to configure the plugin (Stack Trace below). Is there something we can do to make this plugin work the way it's working for Atlassian?
Cause
org.apache.velocity.exception.MethodInvocationException: Invocation of method 'getYesIncrement' in class com.atlassian.confluence.plugins.knowledgebase.ConfigureAction threw exception com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID) at /com/atlassian/confluence/plugins/knowledgebase/configure.vm[line 19, column 107]
at org.apache.velocity.runtime.parser.node.ASTIdentifier.execute(ASTIdentifier.java:223)
caused by: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID)
at com.google.common.cache.CustomConcurrentHashMap$ComputedUncheckedException.get(CustomConcurrentHashMap.java:3305)
caused by: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID)
at net.java.ao.schema.info.SimpleEntityInfoResolver.resolve(SimpleEntityInfoResolver.java:63)
Stack Trace:[hide]
	at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:262)
	at org.apache.velocity.runtime.parser.node.ASTReference.render(ASTReference.java:342)
	at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:336)
	at org.apache.velocity.Template.merge(Template.java:328)
	at org.apache.velocity.Template.merge(Template.java:235)
	at com.opensymphony.webwork.dispatcher.VelocityResult.doExecute(VelocityResult.java:91)
	at com.atlassian.xwork.results.ProfiledVelocityResult.doExecute(ProfiledVelocityResult.java:21)
	at com.atlassian.confluence.setup.webwork.EncodingVelocityResult.doExecute(EncodingVelocityResult.java:48)
	at com.opensymphony.webwork.dispatcher.WebWorkResultSupport.execute(WebWorkResultSupport.java:116)
	at com.opensymphony.xwork.DefaultActionInvocation.executeResult(DefaultActionInvocation.java:263)
	at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:187)
	at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35)
	at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165)
	at com.atlassian.confluence.validation.MessageHolderInterceptor.intercept(MessageHolderInterceptor.java:42)
	at com.atlassian.confluence.util.LoggingContextInterceptor.intercept(LoggingContextInterceptor.java:49)
	at com.atlassian.confluence.core.CancellingInterceptor.intercept(CancellingInterceptor.java:23)
	at com.atlassian.confluence.xwork.HttpMethodValidationInterceptor.intercept(HttpMethodValidationInterceptor.java:72)
	at com.atlassian.confluence.security.websudo.WebSudoInterceptor.intercept(WebSudoInterceptor.java:71)
	at com.atlassian.confluence.themes.ThemeContextInterceptor.intercept(ThemeContextInterceptor.java:68)
	at com.atlassian.confluence.security.actions.PermissionCheckInterceptor.intercept(PermissionCheckInterceptor.java:57)
	at com.atlassian.confluence.setup.webwork.BootstrapAwareInterceptor.intercept(BootstrapAwareInterceptor.java:26)
	at com.atlassian.confluence.user.actions.UserAwareInterceptor.intercept(UserAwareInterceptor.java:58)
	at com.atlassian.confluence.pages.actions.CommentAwareInterceptor.intercept(CommentAwareInterceptor.java:50)
	at com.atlassian.confluence.pages.actions.PageAwareInterceptor.intercept(PageAwareInterceptor.java:151)
	at com.atlassian.confluence.spaces.actions.SpaceAwareInterceptor.intercept(SpaceAwareInterceptor.java:77)
	at com.atlassian.confluence.xwork.FlashScopeInterceptor.intercept(FlashScopeInterceptor.java:25)
	at com.atlassian.confluence.core.actions.LastModifiedInterceptor.intercept(LastModifiedInterceptor.java:31)
	at com.atlassian.confluence.core.ConfluenceAutowireInterceptor.intercept(ConfluenceAutowireInterceptor.java:49)
	at com.atlassian.xwork.interceptors.TransactionalInvocation.invokeAndHandleExceptions(TransactionalInvocation.java:76)
	at com.atlassian.xwork.interceptors.TransactionalInvocation.invokeInTransaction(TransactionalInvocation.java:61)
	at com.atlassian.xwork.interceptors.XWorkTransactionInterceptor.intercept(XWorkTransactionInterceptor.java:56)
	at com.atlassian.confluence.xwork.SetupIncompleteInterceptor.intercept(SetupIncompleteInterceptor.java:43)
	at com.atlassian.confluence.security.interceptors.NosniffSecurityHeaderInterceptor.intercept(NosniffSecurityHeaderInterceptor.java:21)
	at com.atlassian.confluence.security.interceptors.XXSSSecurityHeaderInterceptor.intercept(XXSSSecurityHeaderInterceptor.java:21)
	at com.opensymphony.xwork.DefaultActionProxy.execute(DefaultActionProxy.java:115)
	at com.atlassian.confluence.servlet.ConfluenceServletDispatcher.serviceAction(ConfluenceServletDispatcher.java:57)
	at com.opensymphony.webwork.dispatcher.ServletDispatcher.service(ServletDispatcher.java:199)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at com.atlassian.confluence.web.filter.DebugFilter.doFilter(DebugFilter.java:50)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
	at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
	at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
	at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37)
	at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60)
	at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:70)
	at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
	at com.atlassian.confluence.security.websudo.MessagesDecoratorFilter.doFilter(MessagesDecoratorFilter.java:59)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
	at com.atlassian.confluence.util.profiling.ProfilingPageFilter.doFilter(ProfilingPageFilter.java:44)
	at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61)
	at com.atlassian.confluence.jmx.JmxFilter.doFilter(JmxFilter.java:113)
	at com.atlassian.core.filters.ServletContextThreadLocalFilter.doFilter(ServletContextThreadLocalFilter.java:21)
	at com.atlassian.confluence.util.LoggingContextFilter.doFilter(LoggingContextFilter.java:40)
	at com.atlassian.confluence.util.UserNameHeaderFilter.doFilter(UserNameHeaderFilter.java:26)
	at com.atlassian.confluence.util.UserThreadLocalFilter.doFilter(UserThreadLocalFilter.java:41)
	at com.atlassian.confluence.web.filter.ConfluenceTimeoutFilter.doFilter(ConfluenceTimeoutFilter.java:63)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
	at com.atlassian.confluence.web.filter.ConfluenceSecurityFilter.doFilter(ConfluenceSecurityFilter.java:27)
	at com.atlassian.confluence.web.filter.ThreadLocalCacheFilter.doFilter(ThreadLocalCacheFilter.java:28)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100)
	at com.atlassian.confluence.util.AbstractBootstrapHotSwappingFilter.doFilter(AbstractBootstrapHotSwappingFilter.java:34)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150)
	at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:55)
	at com.atlassian.confluence.util.ClusterHeaderFilter.doFilter(ClusterHeaderFilter.java:42)
	at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:72)
	at org.springframework.orm.hibernate.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:170)
	at com.atlassian.spring.filter.FlushingSpringSessionInViewFilter.doFilterInternal(FlushingSpringSessionInViewFilter.java:29)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:76)
	at com.atlassian.confluence.util.ConfluenceErrorFilter.doFilter(ConfluenceErrorFilter.java:27)
	at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
	at com.atlassian.confluence.core.datetime.RequestTimeThreadLocalFilter.doFilter(RequestTimeThreadLocalFilter.java:41)
	at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:80)
	at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
	at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
	at com.atlassian.confluence.web.filter.ConfluenceTimingFilter.doFilter(ConfluenceTimingFilter.java:75)
	at com.atlassian.confluence.extra.webdav.servlet.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:43)
	at com.atlassian.confluence.web.filter.validateparam.RequestParamValidationFilter.doFilter(RequestParamValidationFilter.java:58)
	at com.atlassian.confluence.web.filter.TranslationModeFilter.doFilter(TranslationModeFilter.java:43)
	at com.atlassian.confluence.plugin.servlet.filter.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:71)
	at com.atlassian.confluence.web.filter.LanguageExtractionFilter.doFilter(LanguageExtractionFilter.java:53)
	at com.atlassian.confluence.util.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:31)
	at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
	at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
	at com.atlassian.confluence.servlet.FourOhFourErrorLoggingFilter.doFilter(FourOhFourErrorLoggingFilter.java:65)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
	at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
	at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
	at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776)
	at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705)
	at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898)
	at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
	at java.lang.Thread.run(Thread.java:744)
Caused by: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID)
	at com.google.common.cache.CustomConcurrentHashMap$ComputingValueReference.compute(CustomConcurrentHashMap.java:3441)
	at com.google.common.cache.CustomConcurrentHashMap$Segment.compute(CustomConcurrentHashMap.java:2322)
	at com.google.common.cache.CustomConcurrentHashMap$Segment.getOrCompute(CustomConcurrentHashMap.java:2291)
	at com.google.common.cache.CustomConcurrentHashMap.getOrCompute(CustomConcurrentHashMap.java:3802)
	at com.google.common.cache.ComputingCache.get(ComputingCache.java:46)
	at com.google.common.cache.AbstractCache.getUnchecked(AbstractCache.java:49)
	at net.java.ao.schema.info.CachingEntityInfoResolver.resolve(CachingEntityInfoResolver.java:32)
	at net.java.ao.EntityManager.resolveEntityInfo(EntityManager.java:1056)
	at net.java.ao.EntityManager.find(EntityManager.java:720)
	at com.atlassian.activeobjects.internal.EntityManagedActiveObjects.find(EntityManagedActiveObjects.java:179)
	at com.atlassian.activeobjects.osgi.DelegatingActiveObjects.find(DelegatingActiveObjects.java:159)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
	at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
	at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
	at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
	at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56)
	at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
	at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
	at com.sun.proxy.$Proxy2217.find(Unknown Source)
	at com.atlassian.confluence.plugins.knowledgebase.DefaultSurveySettingsManager.getSetting(DefaultSurveySettingsManager.java:112)
	at com.atlassian.confluence.plugins.knowledgebase.DefaultSurveySettingsManager.getYesIncrement(DefaultSurveySettingsManager.java:27)
	at com.atlassian.confluence.plugins.knowledgebase.ConfigureAction.getYesIncrement(ConfigureAction.java:54)
	at org.apache.velocity.runtime.parser.node.PropertyExecutor.execute(PropertyExecutor.java:142)
	at org.apache.velocity.util.introspection.UberspectImpl$VelGetterImpl.invoke(UberspectImpl.java:533)
	at org.apache.velocity.runtime.parser.node.ASTIdentifier.execute(ASTIdentifier.java:198)
	... 261 more
Caused by: java.lang.IllegalArgumentException: Invalid Entity definition. Both public abstract int net.java.ao.Entity.getID() and public abstract java.lang.Integer com.atlassian.confluence.plugins.knowledgebase.Settings.getId() generate the same table name (ID)
	at net.java.ao.schema.info.EntityInfoResolverWrapper.resolve(EntityInfoResolverWrapper.java:21)
	at net.java.ao.schema.info.CachingEntityInfoResolver.access$001(CachingEntityInfoResolver.java:11)
	at net.java.ao.schema.info.CachingEntityInfoResolver$1.load(CachingEntityInfoResolver.java:23)
	at net.java.ao.schema.info.CachingEntityInfoResolver$1.load(CachingEntityInfoResolver.java:19)
	at com.google.common.cache.CustomConcurrentHashMap$ComputingValueReference.compute(CustomConcurrentHashMap.java:3426)
	... 302 more
Jorge
December 11, 2013
very good observation. How did they get it to work???
Yesterday I got a message from Jeremy Largman, who has been working on this plugin earlier. He mentioned that he will "schedule this for an update, some time in January most likely".
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
