Why does my ComponentImport Not work?
Diana Bianco August 5, 2020 edited
Hi everyone,
So I am working on the writing an admin space screen tutorial and I'm having trouble with the servlet part. I've updated my pom.xml so that I can use the spring scanner 2.1.8. However, in the tutorial they use the outdated <component-import > tags. I am trying to replace them with the @ComponentImport however it is not working.
package com.atlassian.examples.spring;
import com.atlassian.confluence.spaces.Space;
import com.atlassian.confluence.spaces.SpaceManager;
import com.atlassian.confluence.user.ConfluenceUser;
import com.atlassian.confluence.user.UserAccessor;
import com.atlassian.plugin.spring.scanner.annotation.imports.ComponentImport;
import com.atlassian.sal.api.auth.LoginUriProvider;
import com.atlassian.sal.api.user.UserKey;
import com.atlassian.sal.api.user.UserManager;
import com.atlassian.templaterenderer.TemplateRenderer;
import com.google.common.collect.ImmutableMap;
import javax.inject.Inject;
import javax.inject.Named;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import java.io.IOException;
import java.net.URI;
import static java.util.Objects.requireNonNull;
@Named
public class ViewLinkServlet extends HttpServlet {
private static final String SPACE_ID_KEY = "spaceId";
@ComponentImport
private final UserManager userManager;
@ComponentImport
private final UserAccessor userAccessor;
@ComponentImport
private final LoginUriProvider loginUriProvider;
@ComponentImport
private final SpaceManager spaceManager;
@ComponentImport
private final TemplateRenderer templateRenderer;
@Inject
public ViewLinkServlet( UserManager userManager, UserAccessor userAccessor, LoginUriProvider loginUriProvider,
SpaceManager spaceManager, TemplateRenderer templateRenderer) {
this.userManager = requireNonNull(userManager);
this.userAccessor = requireNonNull(userAccessor);
this.loginUriProvider = requireNonNull(loginUriProvider);
this.spaceManager = requireNonNull(spaceManager);
this.templateRenderer = requireNonNull(templateRenderer);
@Override
protected void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
// Find current user
UserKey userKey = userManager.getRemoteUserKey(request);
ConfluenceUser user = userAccessor.getExistingUserByKey(userKey);
if (userKey == null || user == null) {
redirectToLogin(request, response);
return;
// Find space in the request
Space space = null;
String spaceIdString = request.getParameter(SPACE_ID_KEY);
if (spaceIdString != null) {
try {
long spaceId = Long.parseLong(spaceIdString);
space = spaceManager.getSpace(spaceId);
} catch (NumberFormatException nfe) {
// log a warning if needed
if (space == null) {
response.setStatus(HttpServletResponse.SC_NOT_FOUND);
return;
response.setContentType("text/html;charset=utf-8");
templateRenderer.render("/templates/view-link-action.vm",
ImmutableMap.of("spaceId", space.getId()),
response.getWriter());
private void redirectToLogin(HttpServletRequest request, HttpServletResponse response) throws IOException {
response.sendRedirect(loginUriProvider.getLoginUri(getUri(request)).toASCIIString());
private URI getUri(HttpServletRequest request) {
StringBuffer builder = request.getRequestURL();
if (request.getQueryString() != null) {
builder.append("?");
builder.append(request.getQueryString());
return URI.create(builder.toString());
 What am i doing wrong?
