Wiki markup equivalent for JIRA macro
Jason Friedman
April 3, 2014
I want to create a Confluence page via a RESTful or command line interface and want the page to include the results of JQL.
Bob Swift
April 4, 2014
CLI Plugin for Confluence and then use the getIssueList action.
An example:
{csv:macros=true|autoNumber=true}
{cli:profile=jira|panel=false}
--action getIssueList --project ZJIRACLI --quiet --suppressId --columns "key,id,type,summary,description,fix Versions"
{cli}
{csv}
Only use suppressId if you are on version 3.9.0 or above.
Jason Friedman
April 4, 2014
Hmm. Typically I do something like this to create a page:
$ cat my_file
{toc}
h1. Big heading
Hello World!
Then, I add it:
$ confluence.sh --server http://localhost:8090 --user admin --password PASSWORD addPage --replace --space MYSPACE --title 'MYTITLE' --file my_file
For a JIRA issue list on a wiki page I'm thinking something like this:
$ cat my_file
{toc}
h1. Big Heading
{jira:jql="Project = 'MYPROJECT'"}
But, I don't know what that {jira} macro should like like.
Bob Swift
April 4, 2014
Ah, I mis-understood your question. You are just asking about the wiki parameters for the jira macro? Just do a jira macro and look at the storage format to see what the parameters are and translate into wiki format.
Jason Friedman
April 4, 2014
Perfect, that storage format is useful, thank you Bob! Here's what I did:
{jira:columns=summary,updated|server=OURJIRA|serverId=5f2d82c5-db7e-be3a-3a91-ae5c81b5d4ae|jqlQuery=summary ~ "SOME TEXT"}
Scott Paden
July 18, 2019 edited
Why isn't there a simple markup like {Jira: FOO-123}?  At least in the context of Atlassian cloud where Confluence and Jira are in the same cloud instance / URL.
Scott Paden
OOPS, my bad.  That does work.
